hybird rear deck removal
General discussion area for the L32-chassis Altima
[email protected]
Car: 08 Altima Hybird
How do you remove the rear deck on a hybird to get access to the speakers?
banshee08
Car: 2008 Altima Hybrid
Its not that hard but I suggest you search around and find the FSM (field Service Manual) to see how. Basically here are the steps but the manual will give you a clear idea where the clips for the rear deck is.
1. remove the rear seat cushion by pulling the clips near the bottom of the seat one on each side.2. remove the read seat back bu unbolting two bolts on the bottom. 3. carefully pull the rear deck cover off clip by clip but be careful not to mis-align the EV Battery vent.
If you do it slowly it is not too difficult. Are you thinking of installing new speakers in place of the 6x9??? Be careful not to drop anything below the rear deck, it is a pain to get things out from the there.
-Chan
Return to “4th Generation Altima Sedan (2007-2012)”
