hy35 rb25
HPF Chrisk
Car: 240sx
Is there any one on here running a Hy35 on there rb20/25? what kind of power output and how much boost? i am thinking of running a hy35 so i can have quicker spool time over the hx on my rb25 but i am realisticly wanting 400whp, i will have the supporting mods to do so but i am wondering at what boost do you guys think i can do that at on a holset? at first i wanted to do a hx35 but then after watching some videos it just seems like it has quite a bit of lag, my car is not my dd and is being built as a weekend warrior/track/drift car, thanks in advance
Chris
Cameron
Car: a 240
HX35 with Bullseye power housing will not lag... KAT's run it, B18s run it, and little turbo fords run it.. go with the HX..
youll see full boost depending on high high you got it set by at least 3300
HPF Chrisk
Car: 240sx
3300 in what gear tho 4th? I guess i can just run the hx35 and if i dont like the spool time i will put some cams in it and see if that will help it breath
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
zenkicam, i looked up the Bullseye power housing you were talking about, they do not seem to have one with a T3 inlet, only a Mitsubishi inlet/mount for the house, so a new flange would be need on the manifold, unless you found some t3 HX35 Bullseye power housings somewhere that i didnt?
Cameron
Car: a 240
yea Bullseye Power makes T3 inlets. for Hx35 and Hx40
Cameron
Car: a 240
check the turbo trader.
