hungryjoseph »
https://forums.nicoclub.com/hungryjoseph-u50257.html
Wed Apr 13, 2011 10:06 pm
for the oil feed line into the HX40, what AN size would you guys recommend I use for the oil feed? I was thinking -2 since the hose ID of that is 1/8" (0.125)? from information I found online, the HX40 is supposed to get 70psi max and 7psi min, with recommended 2 - 2.5bar (28 to 35psi) around load. would a -2AN choke the flow to the turbo?
