i was looking at this thread zerothread?id=306777
and he said he used a top mount for clearance and i was wondering if i have to use the top mount manifold or will i be able to use the factory bottom mount manifold?
and i was going to use the n62 maf so i should be able to tune with a safc correct?
also will i have to use bigger injectors or can i use stock on about 12-14 lbs?thanks for the help!
