Yeah I had thought about that after I posted so I'd probably weld the spacer to the manifold anyways. I definitely plan on going with this manifold set up.
ninety1two40 wrote:I'm surprised it fits and doesn't hit the strut tower. This is my setup with a HX35:
But it needed another 1/2" spacer to clear the compressor housing and manifold
If you don't mind me asking what are the dimensions of the spacer?
Also, when it comes to welding on a v band flange for the wastegate, is it the overall outer diameter of the flange used to match the size wastegate you want. I.e. For a 44mm wastegate what size piping and flange do I use?
