HVAC vent actuator parts #27736-70F00
mosilvia
Car: 96 Nissan 240sx
Vent actuator started making clicking noise so I looked for new parts # 27736-70F00
but nobody has it. I founded parts #27736-65F00 actuator for S14.
Does this 27736-65F00 replace 27736-70F00 ?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The -65F00 is a non-domestic part number for the Silvia (JDM and EU, I think), but it fits S14 and S15 so it might work. I think you'll just have to try it.
mosilvia
When I compared the two pictures, the parts were almost the same, but the placement was reversed. Japan is right hand drive
VStar650CL
Technical Expert
The arms are usually flatted on both sides and not D-keyed, so you can probably take it off and swap your arm to it. The question then would be, does it rotate the correct amount in the correct direction? Like I said, you may just need to buy it and see if it will work functionally.
fontana dan
Car: 1997 Infiniti Q45
27736-70F00 is still available in limited numbers. Call around to your local Nissan dealers, they should be able to get one to you.
I ordered one recently from this dealership. I had to call their parts dept phone # for them to enable the part availability on their website, at a discount compared to purchasing it from them in person.
https://www.boronissanparts.com/p/89578 ... 70F00.html
mosilvia
Thank you VStar650CL fontana dan!!
If I can't get 70F00 I try 65F00.
fontana dan
Is it clicking when you change the temperature? 70F00 is the blend door actuator.
Mode door actuator is 27731-70F00
mosilvia
When changing mode switch.
I checked 27736-70F00 was clicking.
27730M in this picture.
fontana dan
That diagram calls 27730M "Actuator Fresh Vent" with same p/n 27736-70F00
interesting. It should click when you hit the recirculation button.
mosilvia
It doesn’t click just one button on the face and feet
