hvac system not working
rodebilder
We have a J 30 we purchase new and it is a 93. Theater/air conditioning control is not working.I have purchased two used units on ebay, plugged them in and they work for a short time then go out. I am assuming it is my wiring harness to this control assembly. Has anyone else had this issue and how did you resolve it.Very much appreciated if someone would [email protected]
driverdriver
Car: NICO's longtime resident Canuck!!!
I'm assuming that when you mention theater/air conditioning control you are talking about the climate control system, correct?
Have you checked the adaptor for fraying wires, etc?
rodebilder
Yes and used a tester light and found only one hot terminal at the plug going into the climate control. Not having a wiring diagram I am not sure if there should be more than one hot wire going in.
I have checked all of the fuses both in the interior kickplate panel and under the hood.
Not sure what i should do next. any help would be very much appreciated.
Thanks
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
I just emailed you the AC Chapter from the manual in PDF format
