CraigB »
https://forums.nicoclub.com/craigb-u9736.html
Wed Mar 17, 2004 3:04 pm
My 1993 Altima GLE's vent system is stuck in defrost mode. The lights on the control head light up when you select the other settings (floor, vent, etc.), but it will only blow through the defrost. I noticed a few months ago that the actuator would over run it's stop and start clicking. Usually if I would turn off the system and wait a minute or two then turn it back on it would go away.
I went ahead and pulled what I think is the actuator. While it was still hooked to the wiring harness I turned the ignition on and tried to get it to yurn to no avail.
So my question is: Is this the actuator?
If yes, should I be able to turn it by hand?
Also, what is this part going to cost me?
Thanks for any help...
