HVAC LED bulbs
PATH2002SE
Car: 2002 Pathfinder SE
I would like to change a few burnt out bulbs in my 2002 Pathfinders HVAC controls. I have seen that a few people have been successful in doing so. Can you please explain how you have done it?
Thanks!! :bigthumb:
chinook1352
Car: 2004 Nissan Pathfinder
When I did mine I just checked my manual to figure out how to take that section of the dash apart. You need to take the vent with the clock in it off first, then there will be some screws you need to remove to take the front of the HVAC controls off. It's fairly straight-forward once you get that first vent off. Just be sure to use a screwdriver with a cloth wrapped around it to pry the vent off so you don't damage anything.
The bulbs you'll need to replace (there's only two), are at the top of the back side of the HVAC controls. You will see two sets of wires leading to a piece of black plastic that holds each bulb. They pop out if you twist them counter-clockwise, and you can just pull the bulbs out.
Hope this helps!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
What size bulbs are they?
chinook1352
Well at autoillumination.com I used the Tri-Power 3 LED Bulb which they say is a #74 bulb that replaces the following bulbs:17 18 37 70 73 79 85 86 2721. So it's one of those :gotme
I'd recommend buying from that site, they fit perfectly and light up the HVAC gauges nicely.
Towncivilian
How many bulbs are there to replace?
PATH2002SE
Do the two bulbs light up the three control and the air recirculation and a/c buttons as well?
chinook1352
Towncivilian wrote:How many bulbs are there to replace?
Two bulbs
chinook1352
PATH2002SE wrote:Do the two bulbs light up the three control and the air recirculation and a/c buttons as well?
Just the three knobs; Fan, Temperature, and Vents. A/C and Air Recirc. are separate.
Towncivilian
Are the A/C and Circulation bulbs also replaceable with LEDs?
Towncivilian
Towncivilian wrote:Are the A/C and Circulation bulbs also replaceable with LEDs?
Anybody know? I'm about to order a bunch of LEDs and would like to know so I don't have to purchase more later.
