911/Q45 »
https://forums.nicoclub.com/911-q45-u148.html
Wed Apr 28, 2004 6:40 am
I've been chasing an HVAC problem for a while now. The system apparently thinks the interior needs more cooling than required after a hot start. Even on relatively cool days the A/C will blast cold air for a few minutes, then realize it's error and resume normal operation. Everything comes out of the appropriate outlets and the fan blows at the correct speed, at least for what it thinks is going on. It works fine on a cold start. The self test indicates all is OK. I've replaced the ambient sensor, the in vehicle sensor and the engine temp sensor near the thermostat that feeds the ECU. According to the FSM that leaves the intake sensor, the sunload sensor, the water temp sensor and the auto amp control box. Sensors are relatively cheap, the control box is very expensive. Is it any use replacing more sensors, or is my likely culprit the auto amp/control panel or perhaps a third draft choice?
