HVAC dimmer wire
Post all your Nissan electronics, car audio and stereo questions here!
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
anyone know which wire is for the dimmer on a 95 max auto climate control? i can't find it on the diagram + i'm not good at reading them.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
What do you need the illumination of the actual dimmer? Illumination is red/black but I don't know the other one off the top of my head (if there is another one)
allensteiner
i want to cut it because i put a red filter in and it's a little too dim with the headlights on - i have my cluster dimmed - so i want to cut it so i can see it well at night. did it to the clock already but can't find the DIMMER wire for the heater display - wouldn't want to cut the illumination one instead
cerveza_fiesta
Car: 1993 Pathfinder SE 4x4
wouldn't a voltmeter tell you?
The line power will be at whatever the battery voltage is.
The dimmer will be at something else.
Alternatively, with a voltmeter you could test which wire has continuity back to the main dimmer switch.
Just a thought.
