Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Apr 11, 2008 6:10 am
Also, double check to make sure that your ignitor's ground is making contact as well as making sure that the power splice at the big chassis plugs next to the battery tray are done up correctly (black/red and blue/red spliced together. blue/red is the 12v supply for the coil packs themselves)
IIRC, maxima coil packs use a different plug than SR coil packs, so did you resolder all the plugs to match the max, or did you alter the packs themselves to fit the SR plug? Just make sure that the plugs are snapped in and secure. And if you did any soldering up there (which I hope you did. Butt connecters for those kind of wires are a big no-no), make sure that nothing is rubbing up against anything funny.
