Actually, it's the near empty tank that puts more load on the pump. A full tank is easier to pump from based on higher pressure at the bottom of the tank. Constantly running on an empty/low tank is the fastest way to kill a fuel pump.superuber wrote:sometimes a full tank will put a load on the pump
Be care about the advice you give online. "Whack" and fuel tank are not really words I would use in the same sentence. Tap maybe? Not saying you don't know what you're doing but there are others that might take you very literally and puncture the tank.superuber wrote:As long as the pump is surrounded by fuel it can cool. It does not have to be full. With a full tank the pump impeller has to work harder to turn because of the extra pressure. The fuel is not just running through a holewhere pressure causes it to run through faster. I have seen many pumps stick because of a full tank, whack the tank with a hammer, bingo! You are right about getting it done asap!
Right, until your FPCU is fried.BobE wrote: What I've read sounds like a few day (& not a lot of driving) should be pretty safe. BobE
I disagree, based on dyno results I've compared- my engine does not care if the tank is full or on fumes, it has the same AFR and timing, same EGT and same power. Its faster with a empty tank as it has to haul around less weight, full tank of gasoline is going to be around 100lbs as each gallon of gasoline is approx 6lbs- its heavier when the gasoline is cooler and more dense. How can you not feel 100lbs worth of weight vs 20lbs ? I guess it doesn't make a big diff on a car the size of a Q due to its porky weight, but when you have a car thats light, every gallon of gasoline counts as dead weight. Hence why drag racers tend to run their cars with close to empty tanks.DrewQ45 wrote:
A full fuel tank gives a positive pressure which actually aids the pump in it's job of fuel delivery... Reason why your car will always feel faster and smoother on a full tank versus empty. Going from full to empty, the pressure decreases and so does that "full tank" feeling.
So am I the only one that feels like the engine is more responsive when a car (any car) has a full tank of gas versus bordering empty? No I haven't dynoed my car with various gas levels but this has been my life long observation using the good old butt-o-meter. Pulling out of a station with a full tank, the car feels noticeably different than it did when I pulled in. I understand what you're saying about drag racers but they are usually running racing fuel, specialized fuel pumps and don't have 20 gal fuel tanks...(the serious ones) so it's a bit like apples to oranges.BlackBirdVQ wrote:
Agreed! It was the first job I ever did on my Q, and it gave me the confidence to work on some other things. In fact, I just did my second fuel pump last night by changing out the one on the Silver Q.redmanfx wrote:Just keep fuel in the tank, say 1/2 or more and you should make it until your new fuel pump and O-ring arrive. Many of us have driven with that "hum" for months before changing it, but ran the risk of frying our FPCM like idiots>> Changing the fuel pump is almost like a right of passage!
Aww phoeey... go ahead and fry that baby. This guy named DrewQ45 has a few to sell anyway!ceningolmo wrote:My Silver one has been humming since I bought it in March. Since I wasn't driving it much during that time I wasn't too worried about the risk. But, still, there was always the chance of frying the FPCU...and that = bad.
