Postby
kenversusryu »
https://forums.nicoclub.com/kenversusryu-u28975.htmlTue Jul 19, 2005 1:11 am
i tried a search but i didn't get anything
So when i'm parked and idling... my transmission hums (foot off all pedals). Kind of makes a whirring humming noise.. When i press down on my clutch an inch or two (around engagement point) at park and idle.. humming stops. When i lift my foot off the clutch.. whirrs and hums again.
Bad clutch? Clutch pedal too high? Free play too high?
95 240sx se.
thanks in advanced.
Modified by kenversusryu at 4:31 AM 7/19/2005
I guess i'll be adding some more transmission oil to see if it gets rid of the sound. If not then i guess i'll just live with it until i get a new clutch with bearing.
if it was a throwout bearing, it would make the noise only when the clutch was depressed. when the clutch is out, the throwout bearing is not spinning.
