humming sound
TmaCular
Car: 1994 Q45 150k
so ive been noticing that sometimes when i start the Q up it makes a whistling sound comin ffrom somewhere up front. but it goes away once runnin for a few. its running fine in when driving . any ideas thanks
1994 q45
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
So, are you humming along with it?
Q45tech
The problem is individual discriptions of sounds in writing vary. Is the whistle like a train or boat whistle, a dog whistle or a human whisting.How long does it last in seconds [exact please], does intensity or pitch vary.
Most people are not trained experienced NOVELIST and may not select the the EXACT appropriate paragraph to fully describe a Sound so that the reader can perfectly duplicate it in their mind.
Why not provide a link to an actual recording?
qship96
Car: 1996 Infiniti Q45
My wild azz guess is he is hearing a squealing belt or failing idler pully bearing........or sleeping cat getting tangled in fan?
fixer
Car: 08 Sentra
maybe an armadillo in the fan
TmaCular
Car: 1994 Q45 150k
ok well i am a novice with this car.. so thx for the advice on posting.. yes the sound is like a train. it does it only right when started in really cold weather..the sound would be on maybe 5 seconds then will go off then sometimes comes back on sometimes doesnt.. i took a look today and it seemed like it was coming possibly from fan?? is there a pully on it or somethin that could go? pitch is lower with no change in pitch.. thank you
qship96
I already told you what the problem is in my first post in this thread.
TmaCular
Car: 1994 Q45 150k
not really definately not a cat... or a belt or pully..any otha ideas
Q451990
TmaCular wrote:not really definately not a cat... or a belt or pully..any otha ideas
I really do think it's an idler pulley bearing. They tend to lock for a few seconds during cold startup, causing a few seconds of a screech. Then you'll get several minutes of a howl that sounds just like a Ford power steering pump... That howl would change with the idle speed though.
A mechanic's stethoscope should help you narrow it down. http://www.harborfreight.com/c...41966
Heath
fixer
Car: 08 Sentra
try shaking the fan blade when the engine is off to see if there is any play in the clutch, the noise might be coming from the fan clutch
fixer
Car: 08 Sentra
also check the water pump. it sits behind the fan and is on the front of the engine, the noise could be transmitting to the fan
