Humming sound from rear
jayturk99
Car: 1995 Infiniti Q45
I have a 1995 Q with a constant hum in the rear. I went into the trunk and it seems to be coming from the fuel pump. Could it possibly be on its last leg? I normally listen to my music w/volume. So the sound just became apparent. The fuel pump looks like an easy plug and play type install, correct me if I'm wrong. Thanks for any assistance.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You're probably correct. Call IoS today and get the O ring and some fuel filters (at least!) too while there is an additional 10% off this month.
http://www.infinitipartsusa.com
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
it is VERY important to get a new o-ring
unless you want to get high off gasoline whenever you put a full tank
Q45tech
O ring is USE ONCE because it stretches into position to seal correctly!!!!!!Removing rear seat and rear storage and package shelf is the hard part.
The unit must be angled up and out.
Most poeple hurry and bend the fuel level sensor and the gauge reads wrong forever after...................slow and careful.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Of course all of this is covered in Tangalora's benchmark post in IOM.
