Humming noise
vanzant
Car: 1998 Infiniti Q45
Just had my power steering pump replaced (it was leaking badly) on my 98 Q45. I was hoping that that was the source of a humming noise coming from engine area. The noise intensifies when accelerating. Any thoughts? Water pump?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
When were the accessory belts last replaced and the pulley bearings inspected?
vanzant
only the PS pump belt was replaced. Pulley bearings have not been inspected. Could the noise be coming from a leaky vacuum hose?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Vacuum hoses usually don't hum, they whistle.
vanzant
It's a medium high pitch. When I acellerate or press on the gas it gets higher. Even when not moving. It makes the same noise in all gears, including park and rev.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
My bet is on a pulley bearing. Check your belts. When you replace the cracked ones, any bearing defect at all requires replacement as any noise or lack of smothness is greatly amplified under operational stress.
You will then realize why when one goes belt bad, all are replaced along with defective pulleys to save on repeat labor or time.
vanzant
Thanks. Question: Do the belts rotate faster as the RPMs increase?
qship96
Car: 1996 Infiniti Q45
Absolutely !!!!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I was expecting a different answer I am Surprised you were so nice.
vanzant
I should have taken a half-second to think about that question before I posted it. Slightly red-faced.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Check your fan clutch assembly. It makes a buzzing noise when the bearing siezes up and causes the fan to spin the engine RPM.
Q45tech
Also alternator and compressor bearings. Measure the pulley diameter vs crankshafy pulley diameters to calculate RPM multiplier.One normally uses their stethoscope to pinpoint the offender.
