Darius »
https://forums.nicoclub.com/darius-u5470.html
Fri Jun 27, 2008 3:53 am
Exhaust noises won't vary with car speed. Its noise will be probably be rpm related. Rev it up in the driveway and see if it makes the sound at a particular rpm. If it doesn't do it in the driveway, take it out to 45-55mph and see if the noise changes when you let off the gas or not. If it doesn't vary with engine load, then it is not the exhaust.
If the car is only 4 years old, I highly doubt that the wheel bearings are bad. My 240 is 11 and I haven't had any issues with them.
About the transmission module, again I highly doubt it is bad. When was the last time you had the transmission fluid changed? Should probably do it every year or two. If you haven't done it, do it regardless of the noise issue.
