StarPD »
https://forums.nicoclub.com/starpd-u54244.html
Tue Feb 13, 2007 10:17 am
Another unusual question for the experts here.
I notice in my new-to-me 2005 Q45 a hum that is sensitive to throttle setting. Either on cruise bcontrol, or manual throttle control. It changes in volume, but not pitch. It seems to be loudest at throttle setting changes. It goes away when the throttle is closed or opened hard on acceleration. It's most noticeable when going over a freeway overpass on cruise control, just before cresting the rise, and after initially entering the return to level pavement. On closed throttle or accelerarion, it goes away completely, and the shutoff of noise is positive and definite. I cannot isolate where the hum is coming from. Turning the sound system and climate control on or off makes no difference. I can't find any other system that I can control that alters the sound either, outside of modulating the throttle. It cannot be heard under no load, when stationary, either at idle or increased RPM. It's not a wind noise, as it's throttle position sensitive when driving only.
My last Q, a '94 Q45t had the dreaded fuel pump hum. This sounds similar, but not exactly the same. On the '94, it tended to be more constant, and never actually went away. It was louder too.
At 24k miles, my new Q shouldn't be experiencing fuel pump wear.
Any ideas?
