BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Sun Jan 20, 2008 1:49 pm
If you are not using the "recirculate" position, and you do not live in a humid climate, you may have a small water leak, or pool of water somewhere inside the car (left a window open during a rainstorm?). I would remove the interior; headliner, carpet, and all; have an assistant spray the car with water, and you'll soon find your leak (if there is one). This is something I had to do with one of my Volkswagens, and I found 12(!!!!!) water leaks. If the car is under warranty, try to leave the interior in place, and do what I mentioned above (spray water from the outside, with someone inside looking for water leaks). Once you confirm a leak, send it over to the dealer to fix.
