huge blinker prob....
pollitoboy
Car: 300zx 2=2 Na
hey guys well ive gtten pulled over 3 ties in 2 days for not using my turn signals....umm wen i try putting em on they dont even wok so i tried swapping the fuses out and still nothing... umm my buddi old me it was a thing thaat makes the clicking noise when ur arrows start flashing.. u know when ur turn signals turn on u hear a click click everythime ithe arrow lights uphell i cant find it.. can anyone show me plzz.. i cant afford a tiket
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Um, not sure what he's talking about...
Kinda sounds like a relay to me. Have you checked the relays under the hood?
Until you get it fixed, use hand signals. Seriously. You might get laughed at but at least it is legal.
pollitoboy
Car: 300zx 2=2 Na
Ace2cool wrote:Um, not sure what he's talking about...
relay? yea i think he mentioned sumthing about that...
Ace2cool
The relay is what controls the flashing. If it's illuminated and not flashing or if it doesn't illuminate at all, chances are it's the relay. If it blinks really fast on one side only, then you have a bulb out on that side. Good news is that relays are really cheap in most cases. Hope this helps.
pollitoboy
Car: 300zx 2=2 Na
Ace2cool wrote:The relay is what controls the flashing. If it's illuminated and not flashing or if it doesn't illuminate at all, chances are it's the relay. If it blinks really fast on one side only, then you have a bulb out on that side. Good news is that relays are really cheap in most cases. Hope this helps.
no no im saying the blinkers dnt work at all ..not the lil arrows or the lil click sounds when the arrow pflashes.. not even my trn signals work.. front and bak
nd_aussie
Car: 1994 300zx 2+2 bout to be tt&1987 rx7 s5 turbo II
pollitoboy wrote:no no im saying the blinkers dnt work at all ..not the lil arrows or the lil click sounds when the arrow pflashes.. not even my trn signals work.. front and bak
sorry to tell you but your going to have to take it to an electrical shop. theres no way to determine where the prob is. unless you want to go and get an electrical tester and check all the blinker wires.
DanDrath
Car: 1990 Nissan 300ZX 2+2 TT
Its a short your going to have to rewire your blinker wire same exact problem happened to me nothing i tryed changing the blinker switch nothing i had a shop run a new wire for the blinker and to the fuse panel that's what the problem was 99 percent is your problem especially if u have the original wiring harness
Weber3211
Car: 1991 Nissan 300zx
easy fix. drain your old blinker fluid and make sure you get some high performance blinker fluid.
tmeyer29
Car: 1990 300zx TT , 04 Yamaha R6
jedijeff123
Car: 1993 Ultra Red 300ZX N/A 2+2(SOLD), 1990 Aztec Red 300ZX Twin Turbo(Temporarily providing a home for a VH45DE)
Weber3211 wrote:easy fix. drain your old blinker fluid and make sure you get some high performance blinker fluid.
That adds, like, 20 RWHP, right, like, hell yeah man, like, yeah!I'd take it to an electrical shop if I were you.
NolimitZ32
Damnit you beat me to it. The relay is called a flasher relay, its usually a $7 part, check if its doing what it should before taking the car to a shop.
tg
if all of them aren't working, its likely the relay. cheap enough fix.
pollitoboy
Car: 300zx 2=2 Na
NolimitZ32 wrote:Damnit you beat me to it. The relay is called a flasher relay, its usually a $7 part, check if its doing what it should before taking the car to a shop.
thank u nolimit u are a god lol...one thing though were is that flasher relay?
300freekzx
Car: 1990 300zx N/A, 1992 Honda Accord LX , 1991 Honda Accord LX, 2006 M35 Sport
That's some funny ish!
DanDrath
Do the hazards work?
pollitoboy
Car: 300zx 2=2 Na
DanDrath wrote:Do the hazards work?
nope not even the hazard light work...
Ace2cool
Ace2cool wrote:Have you checked the relays under the hood?
