would i have to cut and solder any wires or does it just hook right on up94_240sx wrote:No, it won't work. You need harness for the analog cluster.
I've done this on several s13s, and it's all about luck. On some cars, it's easy to remove that black plug, but on some of them, wow... I just wanted to break/cut the dash out. Space is so tight and my hand got scratched up. I wish Nissan made that main harness for the dash like 1 inch longer. Channel lock works great sometimes, but you have to be gentle.kamcam wrote:be prepared to get your arm in the tight space behind the dash to unplug and plug up the harness.
