HUD question
240 SR
Car: 89 240sx w/ sr20
will a 90-94 HUD work with an sr swap?
Modified by 240 SR at 4:40 PM 1/24/2006
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
HUD and SPEEDO - all yearsTACH - 91-94 only
240 SR
do you have a sr swap? why is it opposite for an analog (tach works for all years, speedo needs 91-94)
MagikDragon
nope should be the same as analog, because the speedo uses a sensor from the transmission and all sr and ka trannys are identical. the tach is different because it gets it source from the engine, thats why its the difference between sohc and dohc.
Alfador
Car: 1990 Nissan 240SX Hatch
so that means I need to replace my tach when I swap in a KA24DE... thats a shame...
