onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Thu Jan 05, 2006 9:23 am
Well, if you are going to replace it, I believe the odometer unit can be moved from digi - analog cluster. I have done the odometer from digi -> digi before no problem.
It's not about what smells like what, you need to take the cluster out and check the circuitry.
If the circuitry isn't bad, you have to replace the speedo unit and/or cluster itself.
