Prelude Guy »
https://forums.nicoclub.com/prelude-guy-u19214.html
Thu Oct 07, 2004 4:22 pm
Try this. I had a problem with my Prelude 4 wheel steering. It would work sometimes, and not other times. It turned out to be a problem with the relay soder points. I resodered (basically, I re-added soder) the points, mainly the relay points. Ever since, it has worked.
It is a VERY common problem that has 98% of the time solved the issue.
I recommend pulling out the circuit board and re-soder all of the points. Maybe this will finally be the solution to the HUD issue. It can't hurt, you know.
