emkkremhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=9e87ef654d4f1b719bec3beaedd93545HUD is not working, can I replace it with a normal speedometer?Wed Apr 25, 2007 9:33 pm
also, it's really weird because sometimes the odometer will turn on with the lights and the miles will go, but not the speed....but that's rare...could it be fixable so the speedometer works?
Postby
emkkrem »
https://forums.nicoclub.com/emkkrem-u52466.htmlMon May 07, 2007 11:51 pm
what do u mean? what im thinking is that the whole thing just unplugs, and then just replace it with the analog that will just plug right in, or what do i have to modify? im f-ckin confused man
Postby
s13redtaz »
https://forums.nicoclub.com/s13redtaz-u48627.htmlTue May 08, 2007 3:12 am
to switch from digital to analog you need BOTH the analog cluster and harness. you need to unplug the digital harness and replace with the analog harness. it will be a direct plug and play to swap.
