Hud Display problem
hud240coupe
Car: 1993 240sx SE coupe
I am new over here, but it seems you guys know a lot about 240's. I just purchased my first 240. Its a 93 coupe with the HUD. The hud and the regular speedometer are not lighting up. I found a weird quirk in this though. I can get it to turn on if I start the car, turn on the lights and then turn the car off and on again really fast (without the engine dying). If I do that it works as long as I dont turn the lights off. Any ideas on what to check to make this work?
Mike
JeromeS13
Car: 2008 Subaru Impreza STI
Welcome and use the big flashing Search button at the top. This has been covered thousands of times.
hud240coupe
I used the search option and found plenty of people saying theres work off and on. Mine works with no interuptions once you fool it into turning on. If there was a topic that covered this I would not have asked.
aaronsnocker1
Car: 93 240sx
I'm pretty sure it is the same problem. I would try fixing it like the other threads recommend. I had a s13 with hud and I just put up with the piece of crap not working.
hud240coupe
I would do that but the speedometer does not light up either. I have to have some way to tell how fast I am going.
aaronsnocker1
Car: 93 240sx
If you don't want to fix it then just have a friend drive next to you to determine what rpm is what speed using their speedo. Thats what I did minus the friend I just did it in traffic. That is the super ghetto way to do things though. Try to find a fix. That subject might be a sticky somewhere. I'll have to try and find it.
aaronsnocker1
Car: 93 240sx
Here is one. http://240sx.org/faq/articles/...m.htm another http://240sx.org/faq/articles/dash_light_out.htm
and yet another zerothread?id=158878 This last one is from nico's own article section. This is a great place to come look through and game a lot of good knowledge about your car and cars in general.
icex01x
Car: 93 240sx coupe
aaronsnocker1 wrote:Here is one. http://240sx.org/faq/articles/...m.htm another http://240sx.org/faq/articles/dash_light_out.htm
or if you like pictures zer...83810
hud240coupe
That stuff is all very interesting. I have a different problem though. The rest of my dash works. The lights work fine and my tack and odometer work fine. Just the speedo and hud are not working.
Like I said before if I start the car and then turn on the lights (does not matter if parking or head lights), then turn the key off and on really fast so the car does not die the odometer and hud turn on and work fine as long as I dont turn the lights off.
I cant find anyone that has a similar problem to help me trouble shoot this. It seems that everyone elses lights on the dash and everything go out.
