slakker »
https://forums.nicoclub.com/slakker-u10544.html
Sun Sep 14, 2003 9:19 am
well I had the same problem and I also piulled the guages. Luckily my guages are now working and my solder points arent all the way destroyed. Mine cut in and out. The points which conbtrol the speedo are the two connected to the raised panel behind the speedo itself. The top one sends the signal to the hud the bottom one is where the cluster gets its information. If you unscrew the speedo from the front, on theback of the circuit board connected to where the bottom harness plkugs in those connections are the problem, Just have your friend resolder those points
