Hey guys,
FINALLY got a 240sx! Glad to finally own one of these cars. I've searched for this issue, and have found results but I have it slightly different than I could find. Don't be afraid to be technical, I'm ASE certified for electrical systems.
The dash lights/digital speedo (HUD)/climate control lights are possessed.
The owner before me installed little LED light strips for illumination to the 240sx clear plastic above the radio, I haven't checked what circuit they're spliced into, but I don't think two LED light strips (about 6 LEDs on each) would pull enough current to make the fuse blow so I'm not too concerned about them.
Sum up! What is possessed:
-dash illumination lights (comes in/out)
-HUD digital speedo (comes on when dash lights work, but fades out in 10 seconds)
-climate control illumination lights
-dimmer switch
What I have read:
1) the TCU is a huge problem, so it could just be that since I have an odd set of intermittent issues.
2) if none of the gauges, accessories, and dash lights work it could be the alt (alternator?) fuse... but my tach, fuel, and temp gauges all work.
3) if none of your dash lights and tail lights work then its the rear lights fuse... but my rear tail lights work.
4) if new fuse blows for dash lights, unplug dimmer switch and replace fuse again (shows if dimmer switch is the issue)
5) pull out radio w/harness, check condition of wires (look for exposed wiring that could cause a short)
6) for the HUD, the circuit board for the HUD could be out? But how would that be possible if it comes on then goes out?
Quite an odd set of problems I know... any help is appreciated!
