HUB removal
SlidingRPS13
Car: 89' 240SX Fastback
Putting extended studs in... anyone got and hints to getting this freggin hub out?
struckinc
Car: 93 hatch.stock.well mostly anyway-SOLD
97 kouki-stock
12 sentra sr-wifes new car
97 maxima-wifes car-SOLD
02 maxima se- daily
1936 austin 10/4 lichfield
you can rotate the axles and get to the 4 bolts one at a time ...there are notches in axle boots that allow access....i did my rear end at the same time as my 5 lug and coilovers so it was alot easier with everything out of the way...
180fan
Car: 89 fastback
The hub? You're having trouble getting the nut on the spindle loose or popping the studs out?
SlidingRPS13
(Trying to get the hub w/ studs off) I think I figured it out, noob move... Didnt know you had to take the 4 bolts on the back off in order to remove it.
struckinc
97 kouki-stock
02 maxima se- daily
ummm ok..glad we could be of service
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
What size was the spindle nut?
SlidingRPS13
I already got the spindle nuts off... Is the wheel plate soposed to come off of the hub assembly? (One hub came off nice and clean after nearly breaking my hand with a pull hammer; the other side the wheel plate came completly off of the hub assembly) Think I need some new hubs..
