Hub Diameter???
All things Altima Coupe.
Robs_altima
Car: 2004 350Z Touring
Looking to pick up a 10mm spacer with oversize studs, won't be able to check out my car for another day or two. Would like to order the parts before than so if anyone could help me out it would be a great help. Eibach has a spacer kit for the Maxima in a 5x144 bolt pattern and 66.1mm hub diameter, will it work? Thanks again
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Robs_altima wrote:Looking to pick up a 10mm spacer with oversize studs, won't be able to check out my car for another day or two. Would like to order the parts before than so if anyone could help me out it would be a great help. Eibach has a spacer kit for the Maxima in a 5x144 bolt pattern and 66.1mm hub diameter, will it work? Thanks again
I think that would work but just remember to subtract the thickness of the spacer to the offset of the wheel or you'll rub big time
D-Roll
Car: 08 Nissan 350Z Touring Coupe
Yes it will work, same hub diameter. I have looked into this previously
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
did you mean 114.3?
Robs_altima
Looking for a +35 when finished... The wheels are +45 and need to bumped out. Can anyone confirm the hub diameter?
Robs_altima
LongBeachCoupe wrote:did you mean 114.3?
I was lazy
D-Roll
The 66.10mm is the hub diameter
