Hey guys. So I came home this afternoon from work and went to work on rotating my tires only to find out that one of the lug nuts on the front of my car wouldn't come out. It is not that it just wouldn't budge, the stupid thing is crossthreaded.... . So i'm looking through the factory service manual for my 2002 Nissan Maxima and it doesn't really specify a task unique to this problem, just the procedure for removing the front hub. Looks to me like I'm gonna end up taking the hub out of the wheel bearing just to get to the stupid hub bolts, is this right?? It also says
DISASSEMBLYNFAX0011CAUTION:When removing wheel hub or wheel bearing from knuckle,replace wheel bearing assembly (outer race, inner races andgrease seals) with a new one.
So am I understanding this right? just to replace one stupid hub bolt I have to replace the wheel bearing and all the other pieces that go with it!? That's gonna mean I have to take the assembly to a shop and have the new wheel bearing pressed back in too, right?
Does anyone have a better solution to this problem? Would it be worth my time to try to use a die to try to cut new threads once i get the old nut off? Thanks in advance for any advice fellas. Hope you're all having a good weekend!
