i have one shop like that in town...i mean the guys are all about 50 with 70's mustaches and hair but i haven't met better suspension techs yet.davskins97 wrote:I think I paid $550 for the bearing and a new hub. The old hub was worn from leaving the bad bearing on it too long. I had mine done at a local repair shop, so it's quite a bit cheaper than Nissan or Goodyear would do it for I'm sure. I like to use small shops with knowledgeable mechanics. Most of them know that their only chance at repeat business is to do a good job at a reasonable price. I don't like to pay dealership rates and overblown time estimates for jobs that can be done in 1/2 the time.
i was mistaken, i'm sorry Devon. I found my receipt for the hub & bearing press.allensteiner wrote:lightsout said he paid $600 for parts and labor so you're not too far from that. call around and get some more quotes.
A bearing is made to very tight tolerances (a few tenths of a thousand) and the fit between bearing o.d. and the hub i.d. it presses in must be sized very closely. If the hub is worn (which happens when the old bearing fails and is left in too long) then there will be too much slop between the hub and the bearing. This loose fit will cause the bearing to fail prematurely as the bearing will pivot/wobble inside the hub. You can have the hub inspected to see if the bore is still the correct size, but chances are it will have some wear on it and will therefore be too large for a proper fit.DevonD wrote:oh and one of these sites is http://www.autopartswarehouse.com and another i believe is http://www.partssourceonline.com. as well you are also supposed to replace the hub at the same time..dont know why but thats just what i have been told...
that is exactly how i found out it was the hub bearing.DevonD wrote:I think the biggest indication is if you jack up the tire off the ground and try and rock the wheel back on forth using an in and out motion. If it does rock then your wheel bearing is done. jack up the other side as well so you can feel what it should be like.
