szh wrote:alms24sebring wrote:OMFG..... I mean really. O... M... F... G....
Yet, if he drives a car with GPS in it, then the relativity equations
that are programmed in the software of the satellites and the GPS in the car prove the point - with
complete basis in reality how time and gravity are related!
No "experimentation" to prove anything is needed - the reality of the GPS device is proof indeed.
Ignore the troll.
Z
Oh, come on, now you come out with silly propaganda.
For to start: the calculations made "to correct" the malfunction of the atomic clocks in outer space were made in a basic trial and error method.
There is not a single formula made before the sending of the atomic clocks to outer space, that were made to manufacture the earth's receivers with the corrective device, this is to say, that only after the difference of data between the atomic clocks in space compared with the data of the atomic clocks on earth was calculated, if when the corrective device inside the earth's receivers was manufactured. The calculations weren't made in base of Relativity but in base of the observed difference between datas from the clocks.
Of course, relativists pretend to impose the farse that Relativity's calculations had to be made to find out such a difference, but such is pure crap, the truth is that such calculations to update the different data received from the clocks in space were made in base of experience...not so of predictions.
So, the GPS has never been based in any Relativity, and the calculations have been always been made in base of experience.
Relativity never predicted anything valuable, for example, the famous lie that Relativity predicted the increase of mass because the speed of bodies...such increasing of mass was already an observed fact before Einstein's theories...
I surely will encourage to any poster to stop spreading out lies, come on, just because you are a fanatic of Relativity you don't have to use lies to appear right in front of the rest. Remember that this is not about winning in an argument but to find the truth about the universe, the physical universe...and Relativity surely is doing the contrary, because believing in Relativity is retrurning back to eras when magic ruled, when superstitions were taught in schools, when the imagination of a few men were imposed to the masses.
Fortunately, this is a place in these forums where we can ask for evidence, because science without evidence is void.
So, as you have never presented here time as a physical entity, we have no other choice but to discard any theory which implies it as something that exist in the universe, and we can lean on more accurate explanations which can be perceived with our instruments, that can be even tested, felt, measured, etc, etc...
By empirical and mathematical support, there is not such an extraordinary gravitational lensing but that cosmic dust, variations of temperature, and gases surrounding planets, stars and even galaxies. are the cause of the displacement of the images of bodies located beyond those planets, stars, and galaxies, from our point of view.
Facts rule in science, and cosmic dust, variations of temperature, radiation, gases. etc, etc, have been indeed detected "physically" by our telescopes and instruments...but nobody has ever detected by any means the assumed existence of time.
Science rules, and Relativity IS NOT SCIENCE.
Cheers.
