KA24DE's will not work. You'll need one from a CA18DET as the U.S. pulsar's is different. I have an extra one, so let me know if you're interested.originalsin wrote:it rly looks like a ka24de one would work...i got one if u wana try it/ search to see if it works, ill do liek 20 shipped
I would tear it down and look forward to replacing the oil pump.c-rad wrote:
Looks like I need to get a new pickup screen.... :sigh: There goes another $50. Anyone have a used one they want to let go for cheap?
EDIT: let's hope nothing got sucked up there....
Oil pump was getting replaced anyway. The entire motor is being torn down and thoroughly cleaned (ie: oil passages). I suspected something when the crank didn't turn very easily with the spark plugs out. Then when I pulled the pan and saw the screen, I knew the SHlT hit the fan. Removing the girdle and the main caps just removed all doubt. The journals on the crank really didn't look that bad though. Although its hard to determine wear by sight and feel. At this point I am just going to bring the short block to a machine shop and have them call me when it's ready to go.boost_boy wrote:I would tear it down and look forward to replacing the oil pump.
Dee
That's the funny thing...the oil pan is perfect.OguraPowerTuning wrote:ouch that isnt good. my oil pan on my ca is pretty well dented but luckly it didnt touch the oil pickup. where do you get a new oil pan anyways sence i guess you will need one. i want to get one just to make everything nice and new looking.
Chris, I'll drop you an email! On another note and upon your rebuild, watch the legth of the clutch disk's hub and spline. I've seen a couple of CAs go through this issue with the crank and the bearings/caps catch a beat down. I could never figure it out until I was interviewed by my machinist and then I interviewed other CA owners who had this problem. All of them had a ceramic clutch in their car which tells me that in some cases, the disk was part if not the major problem.c-rad wrote:
So far I am looking at the following--Disassembly and cleaningGetting the crank turned and micropolishedNew main and rod bearingsCylinder hone
Worst case scenario on the crank, I get one from Advance Auto for $190. I'm not TOO upset because now I will have the peace of mind knowing that everything is in good shape when I get it back.
And Dee, I am interested in the pickup. Shoot me an email to [email protected] with how much you want for it shipped all the way up here to Daytona.
Well, I have a SPEC Stg 1 clutch so hopefully that won't be an issue for me. It's just a bottom of the barrell organic disc.boost_boy wrote: Chris, I'll drop you an email! On another note and upon your rebuild, watch the legth of the clutch disk's hub and spline. I've seen a couple of CAs go through this issue with the crank and the bearings/caps catch a beat down. I could never figure it out until I was interviewed by my machinist and then I interviewed other CA owners who had this problem. All of them had a ceramic clutch in their car which tells me that in some cases, the disk was part if not the major problem.
Dee
Go the AutoZone route! I'm pretty sure the bearings will be .25mm over because the crank is cut, so it will be smart to have the engine line bored and the rotating assembly balanced.c-rad wrote:
In other news, I just got off the phone with Advance Auto Parts. They sell a remanned crank that's already micropolished and comes with bearings for $190. Between getting the crank machined, micropolished, and ordering new bearings, it may be more cost effective to just go that route. What do you guys think?
