completely off topic i know, but you website doesnt workMovingviolation240 wrote:You guys (UK) use BHP, not RWHP, so those numbers are off by about 15% from what we quote.
If I'm right....
Paul
What are you on crack? The GT-RS is good for ~350whp or ~400hp . I had an enthalpy tuned ecu with a very similar setup and it put down ~318whp without touching up the tune with an safc. It put out 341whp @16.9lbs boost with the HKS FCon VPro.Dorrell_989 wrote:· Engine o S13 Red Top SR20DET ---2500o HKS GT-RS Turbine Kit ---2095o Border Fuel rail w/ 850cc Injectors ---930 o GReddy Intake Manifold ---474o Blitz LM Intercooler Kit ---890 o GReddy Aluminum Pulley Kit ---235o GReddy Type-R BOV ---215o 300ZX MAF o GReddy Profec-B Spec II Boost Controller ---320o Megan 3" Stainless Steel Downpipe ---120 o Megan Racing Turbo Cat-Back Exhaust ---315o HKS 272 Step 2 Cams ---400o Greddy Rocker Arm Stoppers ---70o Greddy Valve Springs ---190 o Greddy 1.2mm Metal head Gasket ---198o MSD DIS 4 o Power FC
$8952estimated hp is around 500 whp
s15 turbo is good for a solid 300whp, maybe 310-320 with a really good tune.elgarvo616 wrote:the s14 t28 is too small for 350 hp. youre going to need the s15 spec r t28 to get close to your desired goals. cams will help you get to this number ALOT easier. as for the tune, i personally like the ROM tune.
to get in the 400rwhp you dont even need to worry about cams and valves and springs. just metal head gaskets and arp studs. obviously you need basic boltons fmic, 3 in exhaust all the way, piping, intake, etc. your gonna need z32 maf, 740cc or 1000cc(to be safe, if your going e85) injectors. e85 recommended, ive seen almost 40 rwhp and torque gains plus safer and cooler. tomei exhaust manifold, t2871r 64 ar, recommend spitfire ignition coils but not necessary just better for high hp. and most important part is a rom tune, or NIStune but basically do the same thing rom tune cheaper. yea, 400+rwhp easyNicksemianiw wrote:In about 2 months i am doing a top mount turbo setup and my goal is 450 WHP so your telling me i dont really need to worry about my bottom end? all i need to do to safely hold it is a Head gasket,Big turbo,cams, big injectors, AFC,Intake manifold, 300zx TT MAFS swap,Valves,valve springs and really good tuning?
Modified by Nicksemianiw at 8:59 PM 2/20/2005
