HP with basic mods on SR
Troubleshooting, DIY's, How-To's and articles about all Nissan vehicles. Non-vehicle specific "General" How-To and tech information is also here.
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
Everybody knows how much HP a redtop and a blacktop SR make. But a lot of people have been asking 'what will XXX YYY and ZZZ mods give me at the wheels?'
We'll start out with the basics that most people do when they do a swap. FMIC, downpipe, exhaust, and an intake of some form. The most power your going to get out of this settup is about 240rwhp. The stock MAF and injectors both run out of grunt at about that level. Anybody who claims to have over 250rwhp with the stock management system is selling you a load of BS. Everybody also knows that the S14 motor has a bigger turbo (T28) but people fail to realize that this motor will run out of steam at about the same HP level since it shares the same small 370cc injectors as the S13 motor. Now the bigger turbo will be more effecient and spool up a bit quicker, but the peak HP is still limited by the crappy fuel system.
If you don't have the big front mount your going to have to stay down on the boost a bit (no more than about 10psi or your asking for trouble). This is going to put you in or around the 200rwhp level. If you ditch the downpipe your going to loose another 10-15hp and exhaust is worth 5-10.
Also a side note, the stock fuel pump isn't going to support over 8psi (if your lucky) so please don't try it or your going to end up with melted pistons. Upgrade to the Z32TT, Skyline, or Walbro as one of your first mods.
Now let's take our SR with the 'basic' mods (240ish rwhp) and stick a T3/T4 turbo kit on it like the one http://www.enjukuracing.com sells. With this settup your still going to be limited to the 240-250rwhp level due to the stock fuel system. But your going to be making those HP levels at a lower boost level (around 10psi) since the turbo is moving a lot bigger volume of air than the overworked T-2small. Let's throw on some bigger injectors and crank the boost up. 550's a Z32 MAF and some basic tunning will get us up to allmost 400rwhp but will be running on the edge of what they can handle. (it takes about 22psi to make 400rwhp with a basic 'big turbo' settup give or take a few PSI or HP). Now let's go play with the big boys and get up to the 460-480 rwhp range. Now your having to add cams, intake manifold, massive injectors and some really great tunning while still running in the 22psi ballpark. That motor will make over 400hp at as low a boost level as 15psi since it's opperating so much more effeciently.
This is all very basic info, and it's not even half as simple as I make it out to be, but if your a noob it should keep you from getting flamed if you read and understand this from the start. There are also some great articles on turbo's in general in SCC (the suck squeeze bang blow series gets in depth with them pretty well). Please just search before you ask, I'm sure you can find you own answers (which is more satisfying than having sombody feed them to you and safer since you can 'grade' the source as to their credibility)
anyhow, happy boosting
Paul
bvanev
Car: Cars, Snowboarding, photography, Cars
This is really good advice. I have met a few people that think they know what they are talking about. I don't know it all, but if you start asking a few basic questions, and have the general knowledge, obtainable from many books, you can get an idea of you to listen to, and who to blow-off.
P2Motorsport240sx
How many pounds of boost should a stock S13 motor hold with good tuning?
Movingviolation240
It has nothing to do with LBS of boost. PPL need to get over that, it's just a number. You could blow the thing up running 15psi on a T25 or make 500rwhp on a GT30 while pushing 26psi. SR's are going up to 500rwhp and beyond, so the limit is up there (with good tunning of course).
P2Motorsport240sx
So a bone stock sr20det block can hold 500+hp. Not a chance! Rods shatter, pistons crack, rings blow out, bearings spin, head gaskets blow out. So how much boost and or hp can a SR20DET hold with good tuning and without modifcation to the top or bottom end?
Movingviolation240
P2Motorsport240sx wrote:So a bone stock sr20det block can hold 500+hp. Not a chance! Rods shatter, pistons crack, rings blow out, bearings spin, head gaskets blow out. So how much boost and or hp can a SR20DET hold with good tuning and without modifcation to the top or bottom end?
Uh yea, that's why 3 shops are doing it. All it takes is some cams and a headgasket (and maybe valvesprings if you wanna play it safe).
The limit with good tunning is still over 500hp, nobody's hit a real 'brick wall' yet. If you want to use stock cams you can still be on the wild side of 400rwhp (even with stock headgasket). All depends on how much dyno time you buy to set it up.
Paul
Drakon
Car: S13 hatch-SR+bpu's
I think people need to get it ground solid in their minds that upping the HP on a car is not just a 2+2 =4 thing. and most things are not just plug and play. Tuning is always mentioned at the end but i think alot of people dont really get what that means. I dont have experience in it so i can let someone else explain but I have made sure i got the concept.
Movingviolation240
Let me put it this way, before we started tunning on Ken's racecar it made a very impressive 214rwhp. After a few hours on the dyno tweaking the PFC he was over 490rwhp.
It makes all the difference in the world, from a car that makes 200rwhp and looses compression every 6 months to a car that you can drive everyday with 500rwhp.
lessthanjakejohn
P2Motorsport240sx wrote:How many pounds of boost should a stock S13 motor hold with good tuning?
Say something like how many pounds of boost will a stock S13 hold with 100 degree intake temp.
deffe
Hi All US PPL!.
I just recived this URL from a friend of mine. I'm from Sweden my self (that's in europe ;)) so we got alot of CA18DET and SR20DET engines running around the blocks here.
anyway. I just wanted to tell you all a bit about my own experience and feal free to ask something you wounder about since I am not sure I will be fully able to explain it perfectly in english.
... Here we go.
first of. I got a CA18DET Engine with the normal upgrades and a decent turbo (Mitsu 16T #7). I got about 280-300Hp(depending on boost pressure) with stock internals and stock fuelinjectors.
How you ask?.
Well it is simple. Just drill up the matallic tubic thingy that the MAFS is mounted on and that way you will be able to fool the MAFS to think that the car is getting less air then what it is actually getting.
Then you got a new problem the Fuel.. the car will need more fuel since it's now getting more air.. For that, just get a normal fuel pressure regulator. I got it set for 1:1,4 wich is working very well for me.
Also. Regarding the boost and how much you dare to use.. I use 1,5Bar without any problems and a friend of mine with about the same mods is loading 1,9Bar and he got ~320Hp and that's on paper to back it up.
So.... That's that.
toledo240
Movingviolation240, hey whats up? umm I was wondering on your input on high flow cacs? Are they worth it if you have the downpipe and exhaust?
Movingviolation240
not really, just get rid of the cat alltogether, they REALLY hurt turbo car's (a lot more than any NA car)
sellinANs13
yo whats up paul. Havent talked to you in a while. Anyways I just wanted to say that it is possible to get over 250 to the wheels with a stock redtop with basics. This guy at our show named Tony had us install a sr in his coupe. He had a fuel pump, fmic, afc, full exh, and an airfilter. He put down 258 rwhp at 14 psi. This was after tuning it on our wideband dyno (fourth gear pulls, the right way). The car was able to run a 12.7 in the quarter and that was with an open dif. The car was pretty freakish though, but it is possible.
Peace, Dustin (from columbus OH)
GTS4-R
Car: my feet
With a stock IC I wouldn't trust any more than 10psi and with and aftermarket FMIC those injectors can't push much more than 14psi......although I hit 15.4psi withthe factory fuel setup (except I have a Walboro 255iph fuel pump) once when i was tuning my E-01 BC......I wouldn't recommend more than 14 and thats still pushing it.....i think he outlined that above.....
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
I want to settle this for once and for all now where everyone should read it: Common sense suggests that the S14 and s15 t28s will push as much power at 10 psi as the s13 t25 does at 14. 14psi is max on the t25 and 370's, so is 10psi the safe limit for the s14's 370cc injectors? This also seems logical. However Enjuku told me I could push 14 on the S14 SR with stock turbo and injectors. Seems like wishful thinking to me. Wayne at Phase 2 also says 10psi is as far as you want to take it. Paul, what's the deal?
karay240
I don't think that it's a matter of whether or not you CAN do it. I think it's a matter of SHOULD you do it, or how long can you do it. There are some people who seem to get away w/ running all kinds of boost , and the motor seems fine. Others crank up the boost just a little, and that's all she wrote. . . I'm not saying that you shouldn't raise boost levels, and have a little fun, but keep it reasonable. You may be the lucky one w/ the seemingly indestructable motor, or you may not be. . . you can find out the hard way, or you can take precaustions so you won't have to find out. I'll take the latter
Movingviolation240
I've read that 10-12PSI is safe on a T3/T4 (from a reliable source) so I wouldn't worry about running 12-13 on a T-28.
usdm_180sx
Car: 1993 Nissan 240SX base S13
Movingviolation240 wrote:I've read that 10-12PSI is safe on a T3/T4 (from a reliable source) so I wouldn't worry about running 12-13 on a T-28.
Not with the stock smic...
Hijacker
Car: '92 240sx Convertible
'94 F-150
the stock SMIC is good up to 12 PSI, but that's pushing it. an FMIC should be considered long before boost is cranked anyways. I feel they're more effecient than the SMIC's.
BTW, I am currently running 14 PSI of boost (only 12 reaches the throttle body) with the stock fuel pump and have had no problems with pinging or knock. The new walbro just came in the mail and it's going in tomorrow afternoon to give me a safer feeling for running that high of boost.
Return to “Nissan Articles”
