240sx2soon »
https://forums.nicoclub.com/240sx2soon-u26449.html
Fri Jun 03, 2005 8:23 am
And thats the tough part, the Greddy kit is a pretty complete setup the problem is controling it and turning up the boost. Their kit includes injectors (370cc ) which should provide enough fuel for 300whp and an emange that can be tuned but again I think the little turbo runs out of huff around 12 psi or so. I need to find the compressor map for that turbo to see if it will work for me, sending Greddy an email may be pointless but I'm gonna try anyway.What else would I need to bring that kit up to snuff for 300whp? I am thinking it needs around 14-15psi. to make that figure. Tubular amnifold? 3" down pipe? Profec e-01? There is a good article from import tuner on a 240 that used the greddy kit and piggy backed the emange with the profec and acheived 275 to the wheels. I would imagine with that much control over your engine and turbo systm you should be able to make it stand up and sing yankee doodle dandy
Modified by 240sx2soon at 11:42 AM 6/3/2005
