my friend says its a "super 60".. A/R .60, trim .53goldollar wrote:What are the specs on the t3? Also i dont see 300 happening on stock injectors, problly 280ish, but then again with a fpr you could problly pull it out, but if you gave a run down on on the turbo itself it would help answer your question a lil better.
it has compressor a/r .60 and turbine a/r .63. this turbo is upgraded w/ 360 bearing and rated at 350hp.lee_harvey wrote:my friend says its a "super 60".. A/R .60, trim .53
