HP expectations....
USDM_OneVia
Car: Racing
A new shop opened up here and they are having a dyno day on Saturday. $60 will get you 2 pulls w/ wideband and also a quarter mile pull, so I figure, what the hell?
Best way to tell if you have a healthy motor is to dyno it right? So I want to know what kind of numbers I should expect with my current modification status. Here is the list.....
CA18DET.... duhStock turboStock ECUStock MAFStock InjectorsStock CatStock ExhaustGReddy VSPL Front mount intercoolerGReddy hotpipeHeavy Throttle 3 inch downpipeShimmed wastegate.... running almost 12 poundsNGK BCPR6ES-11'sNew o2 sensorWalbro 255lph Fuel PumpZ32 Fuel Filter94 Octane15 degrees of timing2 inch hardpipe intake arm from MAF to turboCrap *** Cone Filter
This will be measured on a dynojet, so I guess the numbers will be a bit more accurate. What approximate numbers should I be laying down to the wheels? I'm kinda excited about this... I am popping my dyno cherry this weekend :) If anyone is in the Cincy area this weekend, shoot me an email, we can go over together then.
Joe
slw240sx
Car: 1990 Ca18det 240sx Hatch
175-200 to the ground! man i wish i could be there with you and with my or the other CA
float_6969
Ditto that. I really wanna dyno my car, but I'm broke as hell right now. Good luck and post pics when you get back!!!
Spectre23
Car: S13 CA, 2013 STi, Tony Kart
This is a little off topic, but... I see you have a Heavy Throttle downpipie. Is it a modified SR downpipe or did they actually make one for the CA? I have read that SR downpipes will work with some modification, but nobody ever says what that "modification" is.
USDM_OneVia
Car: Racing
It's actually a modded SR pipe.
You can get CA downpipes from Australia or the UK, but after shipping and import taxes, it is cheaper, easier, and quicker just to make your own. Here is what I did.....
1) Order your SR downpipe.... any brand, its up to you. Originally I ordered the mild steel one from Heavy Throttle for 130 dollars. They were out of them, so I got the stainless for the same price... BANGIN!
2) When it comes in, take the flange that mounts to the turbo elbow (the one with 3 holes) and carefully dremel out the weld to seperate the flange from the pipe. The HT one had a bevel in the flange that allowed the pipe to slip in so it made the next step a WHOLE lot easier.
3) Get under your car, bolt up the 3 hole flange to the turbo outlet. Then line up the pipe with the cat and hanger. Once this is all lined up, you can then see where you need to make your marks on the flange. Just mark the flange where it needs to be rewelded and take it all down.
4) Give your downpipe and a 6 pack of Corona to your welding buddy and tell him to have at it.
5) Bolt it all back up! It's done!
Basically, the top flange just needs to be rotated about 1/4 turn.
HTH
Joe
float_6969
Thanks for the info Joe. I'd heard you had to rotate the flange, but nothing was ever explained so clearly as you just did.
Spectre23
Yes, thanks for the info.
USDM_OneVia
Car: Racing
That's what we are all here for :)
Joe
Turb0wned
tell us what you get
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
damn...wish i'd have gotten those kind of projected figures. oh well, maybe next time. good luck with it man, kick the fizzuck outta that dynojet for me!
- tim
float_6969
So it's sunday, how'd the dynojet session go?
USDM_OneVia
Car: Racing
Didn't go..... had to stay late at work, but it was worth it, I fired someone :)
But the normal price is like 90 an hour, so I might get a few guys together and see if they can get a group rate together or something.
Joe
float_6969
ouch, they're proud of that aren't they? Glad to know that ruining a person's life made your day. JK! I KNOW that if I had a job where I could fire, people, I'd be the only one working there! Hehehe.
