M4T5 wrote:Lets take my 07 M45 for an example. Engine is rated at 325hp/ 336Lbs Tq @ flywheelThen you add 15hp/ 12Lbs Tq more at the rear wheels over the factory rated rear wheel HP & TQ on a dyno pull. What Hp and Tq figures is the engine producing at the flywheel now?
J
Modified by M4T5 at 7:28 AM 1/11/2009
On a dyno pull, you actually see a decrease in of about 15-20% from the published factory flywheel numbers depending on the car due to driveline loss. Taking the median of 17%, you would be seeing about 270HP and 279 ft/lbs of torque on a dyno pull. This is pretty general as every car is different even from the same factory line.
