hp approximation...?
sunnys14
Car: S14
the dyno in my city is pretty much booked for the next month, so i was just wondering, how much HP do you guys think i am putting out?
t04e 57 trim .50AR compressor .63AR turbine @ 10psi370cc injectors248/248 camsASP pulleyfidanza flywheelact xtreme clutchbd manifoldFMIC 24x12x3 with 2.25 inch charge pipesz32 mafsafc23inch downpipe + blitz nurspec R exhaust
any wild guesses?!?
Modified by sunnys14 at 1:54 PM 10/19/2005
Structure240sx
any timing retard? did you tune with an safc? 250rwhp is possible but it could also be making 220rwhp depending on certain things
K240
Car: 1993 240sx
10 psi on a T04E, My wild guess would be ~ 250whp-275whp
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Too much for 370cc injectors...unless something with your setup is badly wrong.
A 57-trim T04E compressor will do a little over 260rwhp at 10psi...and 370s can only do ~250rwhp as a MAX.
If you're already running 10psi, you're playing with fire...
- Brian
sunnys14
Car: S14
Structure240sx wrote:any timing retard? did you tune with an safc? 250rwhp is possible but it could also be making 220rwhp depending on certain things
i am retarding 2 degrees and am tuning with an SAFC2 with PLX m300 wideband.
sunnys14
Car: S14
:: orion :: wrote:Too much for 370cc injectors...unless something with your setup is badly wrong.
- Brian
so should i not run 10psi with 370cc injectors? GEO is currently running it and im pretty sure he hasnt ran into any problems yet... i hope!
HolyShiznit
Car: Working on my car
Sounds like you need a bit more tuning. The 370cc injectors SHOULD be out of their range at 8-9psi if that's a true T3/T04e. I ran .6 bar or 8.7 psi on 370cc injectors with an SAFC II and timing retarded 3-4 degrees and still trapped 110 all day long. Just be careful.
sunnys14
Car: S14
do you think it would be safe to get a small FMU (like 2:1) to help bump up the fuel pressure just a lil bit to get the 370cc's to flow a bit more for 10psi?
:: orion ::
Rather than a different rate FMU...you can get a adjustable 1:1 ratio FPR.
Bump the base pressure to 4bar (58psi...stock is 3bar, or 43.5psi) ...and 370cc injectors will flow ~410cc IIRC.
That will give you room to grow.
- Brian
Nismochick240
Car: 95 240sx- BONE STOCK.. for now
100000000000000000000000000000 rwhp... good luck keepin it on the road .... lol just kidding
i'm gonna lay a bet down for 324rwhp
K240
Car: 1993 240sx
Nismochick240 wrote:100000000000000000000000000000 rwhp... good luck keepin it on the road .... lol just kidding
You must be on crack!
Craving4Boost
Car: 91 240sx fastback
sunny how are those cams? whats the diff from stock. especially using the 2 exhaust ones. and off topic- how far are you from SF?
sunnys14
Car: S14
im using 248 248 cams. lets your engine breathe better at higher RPMs with the loss of some low end. i live in SAC
sunnys14
Car: S14
:: orion :: wrote:Rather than a different rate FMU...you can get a adjustable 1:1 ratio FPR.
- Brian
would that make my idle really rich!? i guess i can lean it out with my SAFC huh? u have any ideas on which adjustable FPRs to get?
huguetpj
Car: 93 KAT Coupe
If your tuning with a WB02 you should be able to know if the injectors are maxing out or not. But it's best not to run the injectors at 100% duty cycle for extended runs.
Nismo_Freak
Car: 89 Nissan 240SX
- Brian
SR's make 270whp on 370s all day, for years without issue.
Granted it's with an additional amount of fuel pressure, and they are pegged on the flow charts.
:: orion ::
And that's where the newbs get confused...they read "270rwhp on 370s"...and it stops there.
370cc injectors, on a stock KA rail with stock FPR...will only do a little north of ~240rwhp SAFELY.
Of course, if you bump the base pressure they'll do more...that's how I did close to 260rwhp with mine (4bar base pressure).
And "sunnyS14"...yes, tune them down with the S-AFC and wideband...easy stuff.
- Brian
GEO
Car: 95 240sx KA-T
I run 10psi on 370cc's all day.. My turbo is t3/t4 57trim 0.48A/R tho.
sunnys14
Car: S14
i have a slightly bigger turbo than u GEO so i should max out the injectors sooner?
GEO
Car: 95 240sx KA-T
yeh get a TECHTOM or a VV-T on it to see if the injectors pulse are maxed.
:: orion ::
GEO wrote:I run 10psi on 370cc's all day.. My turbo is t3/t4 57trim 0.48A/R tho.
That does not necessarily mean it's safe, though...
Have you dyno'd...??? Do you run a wideband, what are the A/F's...???
Is you base fuel pressure still 43.5psi...???
If you're making less than ~250rwhp for some reason, then it's OK. If you're making more, then you're risking a blow-up.
Simple as that.
- Brian
Craving4Boost
structure helped him through the whole way...and he definatley know what hes doing. Geo was using structures techtom and wideband and he was the one tuning the car.
nissanfanatic
Car: 1992 Nissan 240sx SE
Go run at the track and see what your trap speeds are.
Asphalt dyno>chassis dyno anyways.
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
Im gonna say 300 and 325 ftlbs
GEO
Car: 95 240sx KA-T
I was running 21 Degrees at 40%+ throttle and high 10's low 11's AFR throughtout the RPM rnage
Craving4Boost
geo, i know before anthony got his jwt tune...his ecu was pulling timing but it wasn't consistently the same every time. how is yours? is it the same everytime or does it jump around to 17 to 19 and such and such
GEO
Car: 95 240sx KA-T
it goes to 21 all the time
Structure240sx
we tunned GEO's car to be safe and have good power at the same time. the timing is very consistent. hopefully he gets home again from school and can bring it to the track
sunnys14
Car: S14
GEO! what are you using to control your timing? how much timing were you running at WOT?
Craving4Boost
his ECU automatically retards timing during boost. some of the cars have actually been known to do it. i think its like 4 people out of all ka-t's im not sure. his timing goes to 21 degrees in boost oppose to 28 at WOT which is stock. he used Structures techtom to monitor it
