**HowToWireUpAuto(KA)-Standard(SR)NeedToKnow**
cybertrn
Car: S14.5 & S13R
I have the SR20DE-T swap going into my S13, the only problem is I need to find out where these sensors go or what colors to cut them and put them on the KA transmission harness? I Don't have the SR low harness because the person who was taking off the SR cut it incorrectly where the plugs just connect onto the sensors! So now i am forced to use the automatic harness for my SRswap! This sucks!! But i need to wire two sensors up, i know that there is one sensor that plugs in on the KA Automatic harness and its a plug in play! I just need to know how these other two sensors will be plug or cut and put back together! Thanks Guys!
slow s13
Car: cars, photo, music
The one near the speed sensor(the conector that plugs in) in the rear of the transmission is the neutral swich, the one toward the engine side of the transmission is the reverse switch.
On the neutral swich there should be a black wire that goes to ground, the green with orange strip goes to the ecu pin 35
On the reverse switch there should be a green white that goes to the rear taillights and a green purple that goes to swiched 12v on the fuse block
Modified by slow s13 at 2:29 AM 12/19/2004
Modified by slow s13 at 2:30 AM 12/19/2004
Modified by slow s13 at 2:54 AM 12/19/2004
240dreams
Car: 240's
Thats a pretty clean transmission. Funny pic.
cybertrn
Car: S14.5 & S13R
I got more plugs to install where the block is at!
cybertrn
Car: S14.5 & S13R
Ok! I have the colors for the wires: The Green w/ orange strip is (pin35), green w/ white strips(?),and Green w/ silver dots(?). These wires are for the two plugs on the transmission! Then on another plug(one wire only) there is a yellow w/ with strip and silver dots(?), and on the last plug( two wires)there is a yellow w/ green strip and on the other wire yellow w/black strip(?). That is about it for the transmission harness, the alternator plugs fit with plug and play and the starter too! Just need the chart for the following wires!
cybertrn
Car: S14.5 & S13R
Thanks! But the rain and salt wheather here sucks! Tropical wheather is really bad for this engine!
