HOWTO Adjust the Idle
xns
Car: Computers and cars
How can you lower the idle on a 91 KA24DE? speak in n00b please :D
corn322
Car: 1993 240sx
1. get a FSM2. read FSM
or, unplug the TPS, adjust the idle screw until it idles at 700, then plug TPS back in.
240-4-me
The same question asked a different way, I can't see or find the idle adjustment screw, where is it located on the intake assembly?
corn322
Car: 1993 240sx
from what I've read, the AAV valve or whatever controlls idle is around on the back of the intake manifold
corn322
Car: 1993 240sx
I just went out and looked for it on my '93. it's attatched directly to the back of the intake mani. if you follow the main intake pipe from filter, maf, to the first hose that goes off into vacuum tube world, it goes under the intake runners, down and around to a like 2 inch piece of rubber tube to the AAV valve or whatever it is that controls idle. it's got a phillips (I think) screw for adjustment
popogto
ok, in n00b terms
look at your intake manifold, and there should be a steel wire connected to a spring loaded device, if youre engine is fired up, turn it a few times and your engine should roar, thats the throttle control. theres a screw on it preventing it for going too low.. thats the idle control. unscrew it a few degrees. rpm below 700 will stall easily.
figured this out while doing the SEAFOAM clean because my engine stalled out so i places a peice of paper under the screw to boost the idle.
bcar240
Car: 1993 240SX HB
That may work depending on your situation, but that is not technically the idle adjustment. The idle adjustment screw, as described above, connects to a valve system that changes with the engine condition and will attempt to keep your idle at the same place no matter what. This method will only trick the engine into thinking you are pressing down on the gas a little. But like I said above, it will probably work.
edit: this probably won't work very well to lower the idle, once there is slack in the cable it can't go any lower
xns
my idle is pretty high, so doing this to adjust it may just do the trick
anou
for some reason when it rains my car idles out...like the idle is way to low...whats wrong
