Howdy folks, Spec-V newb here....
clittle760
Car: 2006 Nissan Sentra SE-R Spec V
Just wanted to say hello to everyone here. If this isn't the right forum, may I please make a request that this be moved? I will be picking up my first Nissan ever (an '06 Spec-V) tonight. I'll be trading in a gas-guzzling F-150 for the Spec, and I am looking forward to getting behind the wheel. It's a silver car with the moonroof and I believe the upgraded RF audio. I am a salesman at the dealership where the car is, so I will be driving what I sell now. At least one of my cars will be a Nissan product. Anyway, this looks like a good place with lots of good info and help so I look forward to being a member. Anyone got any thoughts on the '06 Spec-V that I may need to hear first before I go sign the paperwork?
audtatious
Welcome to NICO.
I'm sure someone will speak up to answer your question. Good luck with your purchase.
nametakennow
Car: '06 MINI Cooper S
Check the recall thread and make sure they've dealt with everything at the dealer. Also take care of the butterfly screw issue (Loctite) ASAP.
Have fun!
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
Welcome to the club. The Spec's are great cars. Fun to drive and the QR responds to mods. Make sure though all the recalls are dealt with though.
nissansalesman_wtx
Car: Nissan Sentra
welcome its always good to see another salesman on here. What part of the country are you in? I drive a sentra as well unfortunately my credit did not allow me a spec v had to get an 06 special edition....still a great car though...got my eyes on the 07 spec v...
Anyway ....WELCOME!!
OneFastStanza
Car: '02 Nissan Sentra SE-R Spec V
'92 Nissan Stanza
'97 Nissan Maxim
'04 Saturn Vue Redline
'04 Ford F250
Welcome to the board and congrats on the purchase. There is nothing too major that you have to wory about on the car besides making sure the recalls are taken care of but that isn't a big deal.
SpecVDan
Car: 2006 Nissan Sentra SE-R Spec V (blackout w/ brembo)
ive got an 06 spec v as well, only things ive heard about them is the problems of the qr25de engine itself.
There's the issue with the butterfly screws, which are in the secondary intake runner. They're part of an assembly that rotates to open up the runners at a specific rpm (5000 i believe). Nissan didn't do such a good job on the first ones they put out, i've heard lots of 02-03's have this problem. the screw itself becomes loose and gets sucked into the engine. Supposely it was fixed in the newer models with a new screw design. As a safety precaution, people actually take this out and loctite the screws, to make sure they don't get sucked in.
Another problem is the pre-cat located in the stock exhaust manifold. There have been issues of the pre-cat actually breaking down over time causing tiny pieces of the cat itself to be sucked back into the combustion chamber, which can damage the rings and/or cylinder walls. Most other owners i know of fix this by installing a aftermarket exhaust header. However, you will throw a check engine light, so you must also get a "ghetto sim" which fakes one of the O2 sensors reading to prevent a CEL.
A friend i met has a brother and another friend who had difficulties with the transmission itself. Both of these were 04+. The transmissions were replaced under warranty.
I've heard, but im not sure of a problem with the stock fuel pump going out. Not sure if it is the Spec V, all b15 sentra models or just the 1.8's.
The only problems ive had so far is the rear brakes squeal a little when I back up, normally like from a parking place. It's slowly gone away though. Also, i've never had a fwd with this much torque and such an awesome differential. Under hard acceleration, it will "torque steer" aka pull to one side. To fix this a fellow B15 owner created a underbrace called a "jimmy bar", it connects at 2 or 4 places, depending on which you get, underneath the subframe and ties everything together a bit more. You can find them either on the vboard or b15sentra.net. Another good idea would be to get some motor mount inserts (MMI's), these too will help to lessen that.
sorry i'm a bit late on this info for you hope it helps answer any questions you still have
nismo2K2
Car: 2012 Versa Sedan
hey, are you interested in selling your factory spec v rims? im interested in buyin another set for my 2002 spec v.
