How would these rims fit?
vangj
Car: Cars, Sports
I'm thinking about buying some Works rims for my S14 kouki. They are 18x9.5 and 18x10.5 with a-10 offset. Would these fit good or would they stick out too much? Thanks.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Why don't you just go see yourself with a ruler?
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
vangj wrote:I'm thinking about buying some Works rims for my S14 kouki. They are 18x9.5 and 18x10.5 with a-10 offset. Would these fit good or would they stick out too much? Thanks.
The WHEEL in the rear will stick out almost 2" past the fender. The fronts will stick out roughly the same. Those are wheel sizes used mostly in running a wide body kit or fender flares.
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
Ive came to the conclusion that they dont fit,they dont fit at all.
IDRFT95S14
Car: 1995 Nissan 240sx SE
ddgsxr504
Wow you guys are super immature and unhelpful, another reason NICO is going down the tubes, congrats.
leesredgt
IDRFT95S14
wheres wheel whore sunnys14 hell give u an answer for sure just look at his car in the zenki check in one page before the last
ddgsxr504
leesredgt wrote:
My point exactly
I believe that most of you know nothing about offsets vs wheel sizes let alone tire sizes/aspect ratios anyway.
AZ89two4Tsx
Unless you have pulled fenders/flares/overfenders/whatever they will stick out more than you would like. That is unless you like wheels that stick out around 2". No matter how much you stretch the tires they will stick out. Unless you run rediculous camber, they will stick out.
Crazy offsets like that are usually for people with big body kits and/or huge overfenders. The would look stupid on a daily IMO.
Does that help? Btw, there is a wheels/tires section.
vangj
Car: Cars, Sports
Yea, I kinda figured -10 offset was too way too much. I guess I won't go for it. Thanks for all of the input.
turbo2nr
Car: 97 240sx (kouki)
pull fenders and run lots of camber and stretch the tire and it will fit..
good luck i say make em fit it would look sick
ddgsxr504
I suggest 18x9's all around with a +15/+20 offset.
