silviamaniac »
https://forums.nicoclub.com/silviamaniac-u9235.html
Wed Mar 17, 2004 8:21 pm
I think s15 t28 is way too small for KA. If u want faster spooling and not high HP gain, and since u are looking at used turbo, you probably can look into t3 off rb25det.
Ball bearing center(fast spool), Ceramic turbine wheel(low inertia, fast spool), plastic compressor wheel(low inertia, fast spool!). Everything combined u get a very fast spoolingt turbo. Friend had it on an CA18 back home, real great result.
The only problem is you cant go more tha 12psi, or the turbine wheel will break (Ceramic = weak). Which i think is a good thing for most KA, since they dont see boost more than 10 in normal case. Plus rb25det is 2.5L, KA is 2.4L, compatibility wise, no problem.
However, its really hard to source a good condition one because most of them had been abused.
