I will definitely update....kerrton wrote:Good question, I don't have the answer, my advice would be to ask this question to the service manager directly, and be persistent if he trys to avoid questions. They are a "service" department, so they should be very used to dealing with customers and providing information like this.
Please post back here when you get your car back and any details, it could help a lot of us out if for no other reason than for peace of mind.
I'm very curious what they will do...kerrton wrote:The CVT is a sealed unit, they definately won't be opening that up, even when the changed out my defective CVT they didn't even inspect the internal parts or check the fluid for iron filings, etc., they just ship it back to Nissan. So don't worry about them messing with it, they can't and won't for sure. They'll likely check the fluid, and probably phone a Nissan engineer to help with trouble-shooting or to get advice if this is normal. Or. maybe a more senior tech at the shop with more CVT experience will take over, but either way they won't be doing anything that could damage your car.
What was the issue with your previous CVT that required it to be changed?kerrton wrote:The CVT is a sealed unit, they definately won't be opening that up, even when the changed out my defective CVT they didn't even inspect the internal parts or check the fluid for iron filings, etc., they just ship it back to Nissan. So don't worry about them messing with it, they can't and won't for sure. They'll likely check the fluid, and probably phone a Nissan engineer to help with trouble-shooting or to get advice if this is normal. Or. maybe a more senior tech at the shop with more CVT experience will take over, but either way they won't be doing anything that could damage your car.
That is probably why I was never bothered by it.I really like this feature. Without it, I would not doing more than 30 mpg which is what I am doing right now (and it is not even summer yet).philipa_240sx wrote:If you have ever driven a 4cyl manual transmission car, you can replicate the same vibration by selecting very high gears at low speeds.
Couz, my CVT was replaced because it was defective from the factory, and a few others here have had the same problem. The symptom was the CVT rattle grinding noise which starts very soon after purchasing the vehicle. It is very obvious if you have a defect, and it becomes apparent very early on, so that is a good thing. If you don't hear any strange noises then you're fine, not to worry the CVT is built to last!!!Couz wrote:
And did both CVT's display the slight vibration that is common at 1200rpm and around 30 to 40 mph?
The fact I've gotten the same feedback from so many members here about the cvt behavior regarding the subtle vibrations reassures me big time...philipa_240sx wrote:The low rpm vibration is well documented. It's entirely normal and is a function of the CVT programming.
Reason:
Nissan chose very high gearing during cruising for fuel efficiency. When driving under light load, the CVT selects a very high gear and locks the torque converter. However a 4cyl engine only fires every 180 deg of crank rotation.... which is less frequent than a V6 or V8. This results in more vibration which becomes even more noticeable under these conditions.
I do not feel there are any issues affecting the longevity of the engine or transmission due to the CVT programming. Personally, I have gotten used to the CVT's behaviour and I never notice it.
As for CVT diagnoses, Kerrton explained it...
The CVT is a sealed unit. It's very complex and requires some very specialized tools to service them. Nissan Tech's can only do some basic diagnoses via the computer and change the fluid... that's it. If something is found wrong with the CVT, they simply replace it.
Couz, You seem to have a nice and good dealer. Do you mind share his name?
From what I understand, he should sample the CVT fluid and analyze it to see if it is shot or not (already), and probably check if there are metal pieces in it which would show a premature wear.
See if you can get a copy of the bulletin. I have not seen anything posted yet from my various sources.CPS wrote:Nissan is now setting up bulletins with part numbers for CVT parts. One is very recent, which is fluid pressure switches in the valve body that get replaced depending on the DTC code stored in the ECM. They also have valve body replacement part numbers. You still cannot get any of the CVT cone/belt/etc. components, nor anything that would require splitting the case. Your vehicle may apply to one of the bulletins, and if the code is stored, the technician will replace parts instead of the entire transmission.
If this is true, I'd say it's really good news for the future, if something does go wrong with the CVT after warranty. I think it is complete crap for Nissan to manufacture an essentail powertrain component, which is also one of the most expensive components on the vehicle, implement the technology on basically all of their vehicles except heavy trucks, and then say "we don't service that part if it fails, we only replace the entire unit which costs around $5000". If they build these things, are convinced of their value and committed to the technology, they should support it by offering to service them when they are off warranty, provided the unit is not completely destroyed. While on warranty, they can replace all they want because I'm not paying, but for afterwards they should ensure all of the Service Tech's are trained to repair these and have the tools and manuals required to do so. If this doesn't happen, once millions of CVT vehicles get into higher mileage situations (as I hope to do within the next decade) there could be lots of angry people ditching their Nissans earlier than they'd planned. I'm sure the CVT is durable for the long term, but if and when things do wrong I need that peace of mind that it won't cost me 5 grand to fix. Repairs wouldn't be cheap either, but anything to bring that cost down would help my mindset and increase the enjoyability of the vehicle - I could drive it carefree and not worry so much about listening for odd noises that might be the first signs of an extremely expensive problem.CPS wrote:Nissan is now setting up bulletins with part numbers for CVT parts. One is very recent, which is fluid pressure switches in the valve body that get replaced depending on the DTC code stored in the ECM. They also have valve body replacement part numbers. You still cannot get any of the CVT cone/belt/etc. components, nor anything that would require splitting the case. Your vehicle may apply to one of the bulletins, and if the code is stored, the technician will replace parts instead of the entire transmission.
