How will this fit on my coupe?
xfactor0707
Car: Nissan Altima Coupe 2.5s
http://cgi.ebay.com/ebaymotors...sting
The offsets are
2- 19x8.5 Fronts 5x114.3 offset +35
2- 19x10.5 Rears 5x114.3 offset +22
How will these wheels fit on my Altima coupe?
I dont think they will fit good so thats why im asking
mcheddadi
Car: R8
It's been done should be fine, but you are clearly at the limit there!!
OVRBST wrote:The front rims are nicely tucked in the wheel well, and honestly was debating on whether or not to run a spacer to get them out a little further. No rubbing lock to lock either.I'm running 245's on the 9.5's and it's not really as stretched as I thought it would be.
The rears are 10.5's sporting 275's and again there's no rubbing....yet. The tires are completely flush with the fender. Gives it the widest most aggressive stance possible. The problem will be once it's lowered. I don't think an inch will hurt, and if anything the added negative camber will help. Fender trimming will be mandatory if I plan to attempt to tuck these bad boys at all. I'd say the 10.5's with a 255 would be ideal as it would stretch the tire into the wheel well.
We'll see. I'll post pics later.
FLUSH with the wheel well!
Rolling
you can email the guy for more info:onelowtruk AT aol DOT com
Ferguson
Car: 09 3.5 SE Coupe
17 370Z Nismo
xfactor0707 wrote:2- 19x8.5 Fronts 5x114.3 offset +35
Why do you want to put wheels on the back of the coupe that are 2 inches wider than the front? It's FWD! Unless you just want people to think you have RWD, just put the same size on both ends. The car will be happier.
xfactor0707
Its just really difficult 2 find good sized te37s for the coupe. And the set if found had those offsets
Ferguson
17 370Z Nismo
Okay, fair enough. But you will need wider tires on those 10.5 rims than on the 8.5s. With wider tires on the rear, you will make the car understeer even more than it does in stock trim. If you never corner hard, it may not matter, but if you do, the car will almost be evil.
mrodrig2
Car: 2008 Altima Coupe 2.5S CVT
If you are going to be spending that much money for Volks, why don't you just buy them from one of the authorized dealers in the right size? It's not going to be that much more. http://www.mackinindustries.com/contact.html Call them and find the dealer for your area.
