tjs5012 »
https://forums.nicoclub.com/tjs5012-u104752.html
Mon Oct 19, 2009 7:08 am
My 03 is AWD w/o VDC. I had a no problems in the snow here in central PA. I am part of the snow removal team at the airport, so i usually had to drive to work before the roads were touched, i was never late. Leave the AWD in auto unless you are in deeper snow otherwise the drive train will bind if it finds a dry spot. The only issue i ever found was that in a situation were you may be in a tight turn under power i.e. turning out of a parking lot into traffic, if the front slip, it will activate the rear tires and the transition can cause the back end to step out momentarily. but drive easy (like you should in snow) and you'll never feel the AWD kick in and out. The VDC would be needed in a situation were the AWD is activated, and one front and one ear tire was still spinning ( very slick ice, or stuck in an embankment).
